PDFSIMPLEGEOMOPTIMIZATION system variable
Pdf simple geometry optimization
Enable simple geometry optimization (separate segments to one polyline, use of Bezier curve control points).
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: |
On |
Possible values: | Off (0): Disable simple geometry optimization On (1): Enable simple geometry optimization |
