PDFTTFTEXTASGEOMETRY system variable
Pdf TTF text as geometry
Enable the conversion of True Type font text to geometry. This is useful for when the TTF files are covered by a license that prohibits sharing, or you want to make it harder to extract text.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
Off
Possible values:
Off (0): Don’t convert TTF text to geometry
On (1): Convert TTF text to geometry
