PDFUSEPLOTSTYLES system variable
Pdf use plotstyles
Enables usage of plotstyles. If On, the plotstyle of the layout controls the color and lineweight in the PDF export.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: |
On |
Valori possibili: | Off (0): Disables usage of plotstyles On (1): Enables usage of plotstyles |
