PDFUSEPLOTSTYLES system variable
Pdf use plotstyles
Enables usage of plotstyles. If On, the plotstyle of the layout controls the color and lineweight in the PDF export.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: |
On |
Possible values: | Off (0): Disables usage of plotstyles On (1): Enables usage of plotstyles |
