PDFZOOMTOEXTENTSMODE system variable
Pdf zoom to extents mode
If exporting model space, zoom to extents first, if the current model space view is zoomed in/out. This zooms the layout geometry to the papersize. When Off (0): use scale and papersize from page setup data instead.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: |
On |
Valori possibili: | Off (0): Don’t zoom to extents On (1): Zoom to extents |
