PDFZOOMTOEXTENTSMODE system variable
缩放至实际范围
If exporting model space, zoom to extents first, if the current model space view is zoomed in/out. This zooms the layout geometry to the papersize. When Off (0): use scale and papersize from page setup data instead.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: |
On |
Possible values: | Off (0): Don’t zoom to extents On (1): Zoom to extents |
