PDFZOOMTOEXTENTSMODE system variable
Pdf zoom to extents mode
If exporting model space, zoom to extents first, if the current model space view is zoomed in/out. This zooms the layout geometry to the papersize. When Off (0): use scale and papersize from page setup data instead.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Possible values:
Off (0): Don’t zoom to extents
On (1): Zoom to extents
