PDMODE system variable
Point display mode
Specifies the display style for point entities. The value is stored as a bitcode using the sum of the values of all selected options.
Type: |
Short |
Saved in: |
Drawing |
0 to 100 |
Default value: | 0 |
Possible options: | 1: none 0: . 2: + 3: x 4: ' 32: circle 64: square |
![](https://static.bricsys.com/help/images/V23/en_INTL/SV_pdmode_01_V21.png)
