PEDITACCEPT system variable
Polyline edit accept
Specifies the display of the 'Entity Selected Is Not a Polyline' prompt in PEDIT. When the prompt is suppressed, the selected entity is automatically converted to a polyline.
| Type: | Boolean |
| Saved in: |
Registry |
| Default value: | 0 |
| Possible values: | Off (0): Display prompt On (1): Suppress prompt |
