PICKADD system variable
Pick add
When Off (0): the most recently selected entities become the selection set. Press and hold SHIFT to add entities.
When On newly selected entities are added to the selection set. Press and hold SHIFT to remove entities.
Tipo: | Booleana |
Salvato in: |
Registro di sistema |
Gamma: | |
Valore predefinito: | On |
Valori possibili: | Off (0): Don’t add selected entities to current selection set On (1): Add selected entities to current selection set |
