PICKADD system variable
点选添加
When Off (0): the most recently selected entities become the selection set. Press and hold SHIFT to add entities.
When On newly selected entities are added to the selection set. Press and hold SHIFT to remove entities.
Type: | Boolean |
Saved in: |
Registry |
Range: | |
Default value: | On |
Possible values: | Off (0): Don’t add selected entities to current selection set On (1): Add selected entities to current selection set |
