PICKAUTO system variable
Pick automatic
Specifies automatic window selection (inside or crossing) while selecting entities. The value is stored as a bitcode using the sum of the values of all selected options. A negative value is the same as 0, but helps in storing the earlier value.
Tipo: | Breve |
Salvato in: |
Registro di sistema |
Gamma: | -3 to 3 |
Valore predefinito: | 3 |
Possibili opzioni: | negative: Disables window selection 1: Draws a selection window if mouse is not over any entity when clicked 2: Draws a selection window if mouse is clicked over an entity and dragged |
