PICKBOX system variable
Pick box
Specifies the size (in pixels) of the small square at the end of the selection cursor (the entity selection target) . If you select an entity by clicking, the Pick Box must touch or overlap the entity. Values between 0 and 50 are accepted.
Tipo: | Breve |
Salvato in: |
Registro di sistema |
Gamma: | 0 to 50 |
Valore predefinito: | 4 |
Unità | pixel |
