PICKBOX system variable
选取框高度
Specifies the size (in pixels) of the small square at the end of the selection cursor (the entity selection target) . If you select an entity by clicking, the Pick Box must touch or overlap the entity. Values between 0 and 50 are accepted.
Type: | Short |
Saved in: |
Registry |
Range: | 0 to 50 |
Default value: | 4 |
Unit | pixels |
