PICKDRAG system variable
Pick drag
Specifies the drawing method for the selection window.
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: | 0 |
Valori possibili: | Off (0): Draw selection window using two points On (1): Draw selection window using dragging |
