PICKDRAG system variable
Pick drag
Specifies the drawing method for the selection window.
Type: | Boolean |
Saved in: | Registry |
Default value: | 0 |
Possible values: | Off (0): Draw selection window using two points On (1): Draw selection window using dragging |
