PICKFIRST system variable
Pick first
Allows to select entities first, then issue a command or vice versa.
Tipo: | Booleana |
Salvato in: |
Registro di sistema |
Valore predefinito: | 1 |
Valori possibili: | Off (0): First issue a command, then select entities On (1): First select entities, then issue a command |
