PICKFIRST system variable
先选取
控制运行命令之前 (先选取再运行) 或之后选取对象。
Type: | Boolean |
Saved in: |
Registry |
Default value: | 1 |
Possible values: | Off (0): First issue a command, then select entities On (1): First select entities, then issue a command |
