PICKFIRST system variable
Pick first
Allows to select entities first, then issue a command or vice versa.
Type:
Boolean
Saved in:
Registry
Default value:
1
Possible values:
Off (0): First issue a command, then select entities
On (1): First select entities, then issue a command
