PLINECACHE system variable
多段线缓存
Specifies creation of a cache of polyline vertices when a database file is opened.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
Off
Possible values:
Off (0): Disable polyline cache
On (1): Enable polyline cache
