POINTCLOUDADAPTIVEDISPLAY system variable
点云切换自适应和固定点大小
Point clouds are by default displayed using adaptive point sizes (visually more realistic). However, for point snapping, fixed point sizes are sometimes better.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: | 0 to 1 |
Default value: | 1 |
Possible values: | 0: Use fixed point sizes (all points have the same size) 1: Use adaptive point sizes (point sizes are adjusted for a better visual appearance) |
