POINTCLOUDADAPTIVEDISPLAY system variable
Point cloud toggle adaptive vs. fixed point sizes
Point clouds are by default displayed using adaptive point sizes (visually more realistic). However, for point snapping, fixed point sizes are sometimes better.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: | 0 to 1 |
Default value: | 1 |
Possible values: | 0: Use fixed point sizes (all points have the same size) 1: Use adaptive point sizes (point sizes are adjusted for a better visual appearance) |
