POINTCLOUDCACHEFOLDER system variable
Point Cloud disk cache folder
Specifies the folders where point cloud cache files are stored. Multiple paths are supported. The first one will be used for adding new cached/preprocessed data.
BricsCAD only
Type:
String Standard
Saved in:
Preference
Default value:
{User}AppData/Local/Temp/PointCloudCache
