POINTCLOUDPOINTMAX system variable
Point cloud max points
Maximum number of points displayed per point cloud. Values between 500 000 and 50 000 000 are accepted. This is independent of the number of points present in the dataset, which can be hundreds of billions.
Type:
Short
Saved in:
Registry
Range:
500000 to 50000000
Default value:
4000000
