POLARMODE system variable
极坐标跟踪模式
Specifies the settings for entity snap tracking and polar snap tracking. The value is stored as a bitcode using the sum of the values of all selected options.
Type: | Short |
Saved in: | Registry |
Range: | 0 to 15 |
Default value: | 1 |
Possible options: | 1: 相对(R) 2: 在对象捕捉跟踪中使用极坐标跟踪设置 4: 使用其他极坐标跟踪角度 8: 按 SHIFT 键取得对象捕捉跟踪点 |
