PREVIEWWNDINOPENDLG system variable
文件对话框中显示图形预览
Specifies if the the preview pane is displayed in the Open dialog box.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Range: | On |
Possible values: |
Off (0): Don’t display preview in the Open dialog box On (1): Display preview in the Open dialog box |
