PRINTPDFPREVIEW system variable
Print As PDF Preview
Specifies whether Print As PDF preview uses a system default PDF viewer or an internal program window.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Preferenza |
Gamma: |
0 to 1 |
Valore predefinito: |
1 |
Valori possibili: |
0: Use BricsCAD window 1: Use external viewer |
