PRINTPDFPREVIEW system variable
Print As PDF Preview
Specifies whether Print As PDF preview uses a system default PDF viewer or an internal program window.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: |
0 to 1 |
Default value: |
1 |
Possible values: |
0: Use BricsCAD window 1: Use external viewer |
