PROFILEOFFSETBEHAVIOR system variable
Profile offset behavior
Allows to keep the position of the solid or its axis when changing the profile offset.
BricsCAD only
Type: |
Short |
Saved in: |
Registry |
Range: |
0 to 1 |
Default value: | 0 |
Possible values: |
0: Keep axis 1: Keep solid |
