PROJECTSEARCHPATHS system variable
Project search paths
Stores a list of project names, each holding a list of folders to be searched. If external references and images are not found in the saved path, the project search paths are used to find the external references and images.
Solo-BricsCAD
Tipo: | Stringa |
Salvato in: | Preferenza |
