PROJECTSEARCHPATHS system variable
项目查找路径
Stores a list of project names, each holding a list of folders to be searched. If external references and images are not found in the saved path, the project search paths are used to find the external references and images.
BricsCAD only
Type: | String |
Saved in: | Preference |
