PROJMODE system variable
投影方式
Specifies the projection mode for the TRIM and EXTEND commands. If the cutting entity is not in the same plane as the entity you want to TRIM/EXTEND, this system variable defines how the intersection is to be calculated.
Type: | Short |
Saved in: |
Registry |
Range: |
0 to 2 |
Default value: |
1 |
Possible values: |
0: True 3D mode (no projection) 1: Project to the XY plane of the current UCS 2: Project to the current view plane |
