PROMPTMENU system variable
Prompt menu
Specifies the command prompt menu mode.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: |
Registro di sistema |
Gamma: |
0 to 5 |
Valore predefinito: |
0 |
Valori possibili: |
0: Don't display prompt menu 1: Display prompt menu 2: Display prompt menu at top left corner 3: Display prompt menu at top right corner 4: Display prompt menu at bottom left corner 5: Display prompt menu at bottom right corner |
