PROMPTMENU system variable
提示菜单
Specifies the command prompt menu mode.
BricsCAD only
Type: | Short |
Saved in: |
Registry |
Range: |
0 to 5 |
Default value: |
0 |
Possible values: |
0: Don't display prompt menu 1: Display prompt menu 2: Display prompt menu at top left corner 3: Display prompt menu at top right corner 4: Display prompt menu at bottom left corner 5: Display prompt menu at bottom right corner |
