PROMPTOPTIONFORMAT system variable
Prompt option format
Specifies how command options are displayed in the Command line prompt. A command option has a keyword, a description and a shortcut. The shortcut is the keyword without lower case characters (a-z).
e.g. the third option of the CIRCLE command:
Keyword = TanTanRad
Description = Tangent-Tangent-Radius
Shortcut = TTR
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Preferenza |
Gamma: |
0 to 4 |
Valore predefinito: |
0 |
Valori possibili: |
