PROMPTOPTIONTRANSLATEKEYWORDS system variable
Prompt option translate keywords
Specifies whether translations of command option keywords are loaded or not. If disabled, the local keyword will be a copy of the global (English) keyword. As a result global shortcuts can be used without underscore.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: | On |
Valori possibili: |
Off (0): Don’t load translations of keywords On (1): Load translations of keywords |
