PROMPTOPTIONTRANSLATEKEYWORDS system variable
Prompt option translate keywords
Specifies whether translations of command option keywords are loaded or not. If disabled, the local keyword will be a copy of the global (English) keyword. As a result global shortcuts can be used without underscore.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Possible values:
Off (0): Don’t load translations of keywords
On (1): Load translations of keywords
