PROPERTYPREVIEW system variable
Property preview
Specifies whether selected entities will immediately show property changes when hovering combobox list values in the Properties panel.
Tipo: | Booleana |
Salvato in: |
Registro di sistema |
Valore predefinito: | On |
Valori possibili: |
Off (0): Selected entities won’t show property changes when hovering combobox list values in the Properties panel On (1): Selected entities will show property changes when hovering combobox list values in the Properties panel |
