PROPERTYPREVIEW system variable
Property preview
Specifies whether selected entities will immediately show property changes when hovering combobox list values in the Properties panel.
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Selected entities won’t show property changes when hovering combobox list values in the Properties panel
On (1): Selected entities will show property changes when hovering combobox list values in the Properties panel
