PROPUNITS system variable
Property units
Specifies whether certain types of property values are automatically formatted (e.g. mm²/cm²/m² for areas), when INSUNITS is not zero.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: |
Registro di sistema |
Gamma: |
0 to 255 |
Valore predefinito: |
47 |
Valori possibili: |
1: Format length properties 2: Format area properties 4: Format volume properties 8: (Reserved) 16: Format dynamic dimensions 32: Format mass properties |
