PROPUNITS system variable
Property units
Specifies whether certain types of property values are automatically formatted (e.g. mm²/cm²/m² for areas), when INSUNITS is not zero.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 255
Default value:
47
Possible values:
1: Format length properties
2: Format area properties
4: Format volume properties
8: (Reserved)
16: Format dynamic dimensions
32: Format mass properties
