PROXYGRAPHICS system variable
代理对象图像
Specifies whether images of proxy entities are saved in the drawing. If switched off, a bounding box displays instead.
Type: | Boolean |
Saved in: | Drawing |
Default value: | On |
Possible values: |
Off (0): Don’t save images with the drawing On (1): Save images with the drawing |
