PSLTSCALE system variable
图纸空间线型比例
Specifies the linetype scaling in paper space. If On or 1, the length of the dashes is based on paper space drawing units. Linetypes display identically, in various viewports which are scaled differently. This means that the linetype scaling is independent from the viewport scale. When changing PSLTSCALE, REGEN or REGENALL is needed to update the display.
Type: | Short |
Saved in: | Drawing |
Range: |
0 to 1 |
Default value: |
1 |
Possible values: |
0: 没有特殊线型比例 1: 视口比例决定线型比例 |
