PSTYLEPOLICY system variable
打印样式模式
Specifies whether the color of an entity is associated with its plot style. If PSTYLEPOLICY is 0, the plot style for new entities is set to the default, defined in DEFPLSTYLE and the plot style for new layers is set to the default, defined in DEFLPLSTYLE.
Type:
Short
Saved in:
Registry
Range:
0 to 1
Default value:
1
Possible values:
0: No association between color and plot style
1: Associate an entity's plot style with its color
