PUBLISHALLSHEETS system variable
Publish all sheets
Specifies whether to load the contents of the active document or of all open documents in the Publish dialog box.
Type: | Boolean |
Saved in: |
Registry |
Default value: | On |
Possible values: |
Off (0): Only the contents of the current document automatically load On (1): The contents of all open documents automatically load |
