QAFLAGS system variable
质量保证标识
Internal system variable with flags for Quality Assurance and testing. The value is stored as a bitcode using the sum of the values of all selected options.
Attention: this is subject to change, and not intended for regular use. Some of these options could have unpredictable or unwanted side-effects.
Type: | Short |
Saved in: | Registry |
Range: |
0 to 32767 |
Default value: |
0 |
Possible options: |
1: Red device: no low quality draw 2: No pause during text screen listings 4: No 'alert' dialogs (text display instead) 8: Have Warnings act as Errors and stop scripts 16: Minimal audit report 32: Disable window recreation on switch between 2d and rendered visual styles. 64: Enable various performance measurements printed as info prompts 128: Parallel vectorization: EnableSchedulerLogOutput 256: Cmd message enable 512: Dcl take screenshot 1024: Print time on statusbar 2048: No crash dump file 4096: Create assert log file 8192: Create RED files during rendering 16384: Parallel vectorization performance measurement |
