QAFLAGS system variable
Quality Assurance flags
Internal system variable with flags for Quality Assurance and testing. The value is stored as a bitcode using the sum of the values of all selected options.
Attention: this is subject to change, and not intended for regular use. Some of these options could have unpredictable or unwanted side-effects.
Type:
Short
Saved in:
Registry
Range:
0 to 32767
Default value:
0
Possible options:
1: Red device: no low quality draw
2: No pause during text screen listings
4: No 'alert' dialogs (text display instead)
8: Have Warnings act as Errors and stop scripts
16: Minimal audit report
32: Disable window recreation on switch between 2d and rendered visual styles.
64: Enable various performance measurements printed as info prompts
128: Parallel vectorization: EnableSchedulerLogOutput
256: Cmd message enable
512: Dcl take screenshot
1024: Print time on statusbar
2048: No crash dump file
4096: Create assert log file
8192: Create RED files during rendering
16384: Parallel vectorization performance measurement
