QUADCOMMANDLAUNCH system variable
导航默认命令启动
Enables launching the default quad command without requiring to click on the button. The default quad command depends on which command from the quad is used last.
When 0: hover over an entity to see the quad and click on the command button to launch the command.
When 1: hover over an entity to see the quad and right-click on the entity to launch the command, instead of clicking on the command button first.
BricsCAD only
Type: | Short |
Saved in: | Registry |
Range: |
0 to 1 |
Default value: |
1 |
Possible values: |
0: 按钮运行默认导航命令 1: 当导航显示时点击鼠标右键运行默认导航命令 |
