QUADCOMMANDLAUNCH system variable
Quad default command launch
Enables launching the default quad command without requiring to click on the button. The default quad command depends on which command from the quad is used last.
When 0: hover over an entity to see the quad and click on the command button to launch the command.
When 1: hover over an entity to see the quad and right-click on the entity to launch the command, instead of clicking on the command button first.
BricsCAD only
Type: | Short |
Saved in: | Registry |
Range: |
0 to 1 |
Default value: |
1 |
Possible values: |
0: Launch default quad command only by pressing button 1: Launch default quad command on mouse right-click when quad is displayed |
