QUADDISPLAY system variable
Quad display
Specifies when to display the quad. When the value is 8: suppress the quad when hovering over entities that are not in the current selection set; set Show Quad on right-clickON to display the Quad. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
-15 to 15
Default value:
5
Possible options:
negative: Switch off quad
1: Display the quad when the cursor hovers on an entity
2: Display the quad when entities are selected
4: Display the quad on right click
8: Suppress the quad on hover when entities are selected
